DVD player
How can I play my DVD player while driving.
You must have a son named for connecting e-brake. Take this thread, and put each pin diagnostic port while the car is switched on when you find one that bridges the gap it play DVD on this one. You may have to put a toggle switch in line so that it will mislead the reader. That's what I did and can not be the best option. I hope it helps.
You should have a wire designated for the e-brake hookup.The one wire that has to get hooked up to the Emergency brake to the DVD unit that your vehicle is in park,just attach a power with switch to turn it on and off.Ground it oout and wire a toggle switch in line.If the screen requiers more than on pulse to activete then the toggle switch serves its purpose as well as allowing you to kill the picture if you ever get pulled over.
You should have specified e-brake cable network. Taking this line, and diagnosis of each port pin it, while the car is, when you find a DVD player to splice into the one. You may have to meet the switch so that it will fool the players. This is what I did, not necessarily the best choice. Hope it helps.
First thing is that you should have a wire designated for the e-brake hookup
and also you have to do change to another power supply. After this toggle switch and run the player the wire goes normally to the brake and thus type you can play the DVD player. |
You should have the wire designated for e-brake hookup. Take that wire, and put it in each pin of the diagnostic port while the car is on, when you find the one that makes the dvd play splice it on to that one. You may have to put the toggle switch in line so that will fool the player. Hope it helps.
