Radio code help please
Old Dec 7, 2022 | 07:57 PM
Rxnxgxdx's Avatar
Default Radio code help please
S/N: T00BE047156264
Supplier: 36670
Type: NTG4 RHR
P68043516ae
Old Dec 8, 2022 | 03:01 AM
Originally Posted by Rxnxgxdx
S/N: T00BE047156264
Supplier: 36670
Type: NTG4 RHR
P68043516ae
try code 5060
Old Dec 8, 2022 | 06:04 AM
Rxnxgxdx's Avatar
Originally Posted by amilo
try code 5060
It goes back to this
Old Dec 8, 2022 | 06:55 AM
5060 has been checked and is the correct four digit code for the number on the screen
Check the label on the metal casing to make sure the number on the screen is the same one as is printed on the label.
If it is the same , then if the radio has had a recent software download then try one of the default codes 0000 1234 1111 or 1115
If it still fails to work the it will be a job for a Radio Decoding Service because it could have been recoded in the past to a different number
Old Dec 8, 2022 | 07:51 AM
Rxnxgxdx's Avatar
How can it be changed ?? And here only other numbers on it
thsts the DVD part
Old Dec 8, 2022 | 08:18 AM
I have seen Serial Numbers on the screen being different to the ones printed on the case label or stamped in the metal.
You have exhausted all my suggestions (see previous post) so if none of them work then it will have to be taken into a Radio Decoding Service to be decoded
Ken_P
Sep 11, 2023 06:19 PM
TONY ANDREA104
Nov 7, 2022 06:36 PM
Edsino
Jul 26, 2022 07:32 AM
Ali AL-Baaj
Aug 15, 2019 04:16 AM
nichard
Dec 10, 2010 11:39 AM
