04 Convertible Blower Motor not working
I have an 04 Sebring Convertible that just this am the blower motor stopped working. I've had problems with past Sebrings where the resistor goes out & it works on high, but this is NOTHING. Fuse is ok. Any help would be appreciated!!!
2 things.....
First ...put the control on high, and using a small hammer, or a crescent wrench....Tap the bottom of the motor....If it runs after hitting it, replace it... Second.....Resistors can burn out AFTER the high speed tap-off also...It IS ABSOLUTELY UNTRUE that a bad resistor will ALWAYS only give you HIGH , That is just simply the more common scenario. 04????? Hmmmm......Its possible you dont have a resistor, but rather a BLOWER MODULE....Which performs the same function, is bolted in the same hole, and looks Identical until you remove it and hold it next to a conventional resistor......The Module will have a large alumminum finned "HEAT SINK" as opposed to the resistors "EPOXY DIPPED" finish. THEY ARE NOT INTERCHANGEABLE....... You did check power and ground to the motor didnt you???? |
Actually no, it just happened today so I haven't had a chance. It was just strange that I parked it in the garage Saturday & it was working, then left for work today & nothing!
