04 seabring electrical problem
here is the strange problem I am having. All four of my power windows do not work. Also my dome light does not come on when I open the drivers door but does when any other door is opened. Any help would be great.
These are two separate problems. There's a circuit breaker for the power windows located in the junction block You will find that at the left end of the instrument panel under the cover that will be visible when you open the driver's door. Check circuit breaker number 2.
The dome light problem may be a bad switch on the driver's door. |
