05 2.7L 6cyl spark plug access
How do I gain access to the spark plugs? When I remove the top manifold deep set bolts it won't budge. Are there other bolts connecting it?
You do NOT need to remove the intake manifold to remove the spark plugs. Remove the coils, remove the insulation blanket on the firewall and you'll be able to "roll in" a spark plug socket using a universal joint between two short extensions.
