06 radiator replacement help
My girlfriend has an '06 Sebring Convertible with the four cylinder motor. She has a leak in the radiator. I have been looking around trying to find information on how the radiator actually comes out. It looks like the intake is in the way of getting it out.
Is there any information that would help me make the job easier or just some tips? It doesn't look like an easy task and I don't want to just start removing parts that I don't need to. Any help would be appreciated. I did a search on this site but couldn't find anything on it. |
There's a steel piece that goes across the top of the radiator that you must unbolt and remove. Then you will be able to lift the radiator straight up. You will need to unfasten and remove the fans. As I recall, the worst part was unhooking the lower radiator hose, but even that wasn't too bad. The lower mounts take the brunt of abuse and may need replacing. You can get those only through the dealer. If you are uncertain about doing it yourself, buy a Haynes manual and read through the instructions. Then you can decide whether you and your toolbox are up to it.
