07 Sebring Engine Oil Temp Sensor
Old Nov 6, 2010 | 11:49 PM
rossftn's Avatar
Default 07 Sebring Engine Oil Temp Sensor
Hi All,
I have an 07 Sebring with the 2.4L 4 cylinder. The check engine light came on, and my tester showed a P0196 code - Engine Oil Temperature Sensor fault.
My problem is that I have no idea where the engine oil temp sensor is so that I can test it and inspect the wiring. Chiltons doesn't have a manual. I also search this and other sites extensively and found nothing. Does anyone know the location of the engine oil temp sensor for the 2.4L 4 cylinder? Any help would be greatly appreciated. Thanks.
Old Nov 7, 2010 | 07:39 AM
Default Location
this is the only pic of it
Old Nov 7, 2010 | 04:11 PM
rossftn's Avatar
Thank you so much for the picture, but unfortunately I can't open it. A message comes up saying that I don't have the privelidges. I am a member and am logged on, so I don't know what is wrong. Frustrating!
Old Nov 7, 2010 | 10:20 PM
top of the engine remove the cover look right by one of the dowel pins that holds the cover in place
Old Nov 8, 2010 | 09:29 PM
rossftn's Avatar
Thanks! And you are positive this is the engine oil temp sensor and not the coolant sensor?
I'll check it out.
gr00vyd0
14
Aug 29, 2020 01:53 AM
Yacky
Dec 8, 2011 05:17 PM
trvman
Oct 21, 2010 11:14 AM
Kazzybrown
Sep 22, 2010 01:06 PM
longiron
Apr 24, 2010 06:34 AM
