1996 4cyd die after running awhile
11 - Intermittent loss of crankshaft and/or camshaft position sensor signals to PCM
12 - Battery disconnected within the last 50 starts
33 - Air conditioning clutch relay circuit. An open or shorted condition detected in the air conditining clutch circuit.
55 - Just tells you that this is the end of the codes.
Might want to check the crank and cam position sensors. Seems like they tend to take each other out when they fail on the four cylinder engine.
