1998 Door Won't Close
Any suggestions? My daughter has a 1998 Sebring she was having trouble with the drivers door not shutting about a year ago. I thought that the hinges may have worn out. But on inpection I could not see any wear on the hinges. So I decided to remove the door, I found that the pillar where the top hinge bolts to was cracking and starting to pull out. So I took a hammer and tapped it back into place cleaned it and welded the cracks. I installed the door and it worked perfectly for about a year. She stopped by this evening and said her door was not closing right again. I am afraid that it has broken out again. I was hoping that someone would have a better fix for this.
Thanks. |
weld away
