1999 Chrysler Sebring JXI odommeter failure
I have a 1999 JXI. The digital odometer stopped working; all other idiot lights work. Before I pull the dash I'd like to know my options.
Haha! none. if the digital cluster works anything like I think it does, the mileage is hard coded into the cluster itself. not only will you need to completely replace the cluster, you'll need someone to re-code the cluster with your mileage, lest you get a title issue if you ever go to sell the car.
I just fixed a similar issue on my '96 only the entire dash was out. I got a replacement dash from the junk yard. The mileage is stored in the BCM so you don't have to worry about that. A replacement is cheap and so easy to install that I would probably start there. In researching my problem I saw a lot of people had problems with this dash, especially the odometer and tach.
Steve B. |
