1999 Sebring JXI 2.5L
Old Mar 20, 2012 | 11:37 AM
atravis4's Avatar
Default 1999 Sebring JXI 2.5L
What should voltage be at the ASD plug for distributor when engine is turning over? I guess I am asking if I should have a high or a low when turning over? I have o.o volts with key on and 11.9v when turning over. If 11.9 is correct does this indicate CPS is functioning? No spark is the issue. Just trying to narrow down what I need to replace. Also the fuel pump will come on momentarily 2 secs at most when the key is turned to the on position.
Alan
Old Mar 20, 2012 | 02:24 PM
it is working correctly U have a distributor assembly issue replace it
Old Mar 20, 2012 | 02:40 PM
atravis4's Avatar
Thanks Kevin for the info and prompt reply!
Old May 6, 2012 | 02:51 PM
atravis4's Avatar
New distributor solved the issue.
Old May 6, 2012 | 05:54 PM
good deal
AIRaquarian
Dec 2, 2012 09:32 PM
Jd61987
Sep 11, 2011 09:21 PM
DJBowens
Apr 26, 2011 05:44 PM
docergo
May 21, 2010 08:22 AM
n1rsp
Sep 24, 2008 12:40 PM
