2.7 Sebring
When idling for approx 2-3minutes engine hesitates then goes back to normal idle this doesn"t occur at normal stop and go situations only idling otherwise so far runs fine-any suggestions
Billy |
RE: 2.7 Sebring
Have your codes checked.
If no codes are present, could be EGR leakage, Idle Air Control valve failure, TPS sensor, Crankshaft position sensor, Camshaft position sensor, the list goes on. Hopefully you have a code to direct you. |
RE: 2.7 Sebring
Could be due for spark plugs. How many miles on that thing?
