20 Amp Ignition /starter fuse keeps blowing
2002 Sebring
20 Amp Ignition /starter fuse keeps blowing solution please. Thank you |
What has been done just PRIOR to this happening??? Start there, SOMETHING is grounding(shorting out) to blow that fuse.
dead battery
I know you posted of an ignition key issue not long ago, if you truly want help you need to tell us of what has been happening and what was done...We don't have X-ray eyes to see where an electrical short(blows fuses) is coming from. IF you have been doing work yourself, fess up and say so, we respond to try and HELP but are not the factory engineers. If a shop has been working on it and has happened right after...get in touch with them.
Replaced battery. everything seems to be working fine,
Thank you for the responses |
