20003 sebring corvertable power top not working
Old May 13, 2020 | 01:15 PM
fyshbyte's Avatar
Default 2003 sebring corvertable power top not working
2003 Sebring convertible Limited power top and power windows not working
Old May 13, 2020 | 02:47 PM
REBEL59's Avatar
OK, I'll "byte"....
Nice weather has come around in the USA FINALLY,has the car been in use and just done this or was it in storage and just bringing it out for use again?
Did you check the fuses for those features on the fuse panel?
Old May 13, 2020 | 05:37 PM
fyshbyte's Avatar
Hi Rebel how are you?
yes the relay (fuse) under the dash next to power seat.- fuse looks good , i swapped them still nothing
I use the car everyday
Old May 14, 2020 | 10:54 AM
Take a look at fuse #17 in the fuse panel that's under the hood (Power Distribution Center). It's the one that covers the convertible top up and down function.
Old May 14, 2020 | 01:32 PM
fyshbyte's Avatar
Default fuse17
Fuse is good still no top or window function
Old May 14, 2020 | 03:05 PM
Next step would probably be to check the switch operation. The switch for the top also runs the windows down. You'll be removing the center console to get to the contacts of the switch. Because of the difficulty of getting in there, you might want to track down a replacement switch first.
Old May 14, 2020 | 04:41 PM
fyshbyte's Avatar
ok will track down a switch. Thank you for staying on top of the situation. will get back to you soon
Old May 14, 2020 | 04:44 PM
fyshbyte's Avatar
Old May 19, 2020 | 11:05 AM
fyshbyte's Avatar
checked the 30 amp fuse link under the dash for power windows there was no voltage, so ran a 12.volt line to it and it powers up the windows . do you know why there is no voltage there?
Old May 19, 2020 | 02:58 PM
Power for the windows must pass through the ignition key switch. Trace the line back to that and see if you are getting power from the switch. Obviously, the switch must be turned on.
