2001 Chrysler Sebring headlights and tail lights
Hi guys, I am obviously new to this forum and just purchased a 2001 Sebring Lxi coupe from a friend. I need to replace the headlights, they are very worn out so it is time sensitive that I fix this issue for inspection. I need to know where I can purchase after market headlights and tail lights, not just bulbs but assemblies. If there is projector style headlights I would prefer that. I noticed a lot of market for the 03-05 sebring coupe's as they are a different body style but I noticed that the tail lights from the 01-02 coupes are visually the same as the 03-05 coupes, are they interchangeable? if not is it a wiring issue? Also upon research I have not found much in headlights for the 01-02 coupe either, are any manufacturers out there, perhaps even members on this forum who modify etc? If anyone could help me out on this issue, def. appreciate it. Thanks for your time.
Try searching eBay motors for "headlight sebring coupe 2001" and see what comes up.
If the lights are cloudy and yellowed, you might want to consider buying a polishing kit and polishing them up. There are lots of choices out there for cleaning up old headlights and they work reasonably well, probably well enough to pass inspection. Replacement lights will set you back over $100 each, whereas a cleaning kit is far less, maybe $15. |
Another possibility is your local wreckers yard .... just a thought.
Check this link ... http://www.autopartswarehouse.com/sh...r/sebring.html |
