2001 sebring codes, codes and more codes
Old Jul 27, 2014 | 10:14 PM
Jfizzle's Avatar
Default 2001 sebring codes, codes and more codes
First time poster because I am stumped. Here is a little background.
I just recently came into possession of a 2001 sebring 3.7. I got a smoking deal on it and figured I could run it back and forth to work as it was supposed to have no mechanical or electrical problems. I expected to stick some money into it just wished it was not an electrical problem.
So here is my problem. When I test drove the vehicle there were no check engine lights on. When I got the car home and restarted it the CEL light was on. I did the on off technique to get the codes. There are 10 codes. P0351 through p0356 (ignition coil circuit per cylinder) 0123 high voltage at tps, 1193 high voltage at inlet air temp, 1289 manifold tune valve solenoid circuit. The last one is 1684 disconnected battery (which explains why there were no codes when I test drove it)
All that being said the car runs good but starts a little tough. Used a quarter of a tank of gas going about 40 miles so I am suspecting it is not running as good as it should. My main question is what would be causing these codes if it is still running. Also is there a way to check the computer as that seems to be my first step. I do not think that all coils went bad at once without something forcing them to go bad. I have done a lot of work on jeeps and old Chevys so I am pretty mechanically inclined but I am about as smart as a 2 year old when it comes to electrical systems.
Thanks in advance for any insight or help.
JFizzle
Old Jul 28, 2014 | 08:51 AM
Start with a careful visual inspection if the engine wiring harness, make sure all connectors are clean and tightly connected, no shorts or damaged insulation. Replacement of the computer is pretty far down the list of priorities at this point.
When in doubt, deal with the cheapest things first.
Old Sep 16, 2018 | 06:26 PM
n2gun's Avatar
Default Head unit reset and BAM, DENIED!
Need a code! Please and Thanks!
Any chance on this one?
Old Sep 17, 2018 | 03:33 PM
I have no idea what you are asking about, what kind of car, where you are located and what you want answered. Try reading your own post from the perspective of somebody who might come along here and ask yourself "What is he talking about?". When you figure out what you want to ask, open up a new thread and post up your question. Include necessary background information like make, model, year, engine, mileage etc. If you are looking for a stereo code you won't get it here. Those things are for theft protection and if it were that easy it wouldn't be much good for that.
Old Nov 6, 2018 | 12:11 AM
Azsolt's Avatar
Default Chrysler rádió code
Old Nov 11, 2018 | 11:40 PM
nauman_mustafa's Avatar
Hi Dear,
I already checked above mention points properly but problem didn't solved yet. I don't know what's going with me.
Felling worry for that!
Old Nov 21, 2018 | 12:13 PM
Fábio Teixeira's Avatar
Hi
I recently buy a Grand Voyager (2004)
Can you help me with the radio code
Thanks in advance
Old Dec 12, 2018 | 03:54 AM
gacho2013's Avatar
please need code
Old Dec 28, 2018 | 04:09 AM
device's Avatar
Help pls
Old Dec 29, 2018 | 09:28 PM
alejonicole's Avatar
Please, help!!
Radio brand HARMAN
Model VP4 NAQ
Type CMC
Supplier 36670J
IC ID 6434C-BE2801
XM ID XBJQ54C3
Bar code: T00BE181472618
Bar code: 68190260AE
Car VIN 1C3CCCCB1FN548592
