2001 Sebring Door Handle Linkage Rod
The inside passenger door handle of my 4 Door Sebring Seda (2001) isn't working. After taking off the door panel to investigate it appears that the linkage/rod from the inside door handle to the door lock linkage has come off. Of course, it came off by the lock way inside the door and I have no idea how to put it back on, or what it is called in order to get a replacement. The door opens from the outside and the lock works fine...I just can't open the door from the inside.Also, the little red plastic piece that the rod sits in appears to be getting worn out...any help would be greatly appreciated.
Matt |
RE: 2001 Sebring Door Handle Linkage Rod
no science behind this one just get back there and re attach it u cant get thettle red clips by them self.
I will give it a shot. Do you know the actual name or part number for the linkage? It appears that this one might be bent. I appreciate your help!
