2003 Sebring wipers not working
2003 Sebring LX, 2.4L, 4 cylinder, sedan.
Fuse is ok. Fluid works. Replaced the switch in the steering wheel and still won't work. When turning the wipers on, nothing happens. No noise. Washer fluid works. Should I try replacing the motor next. If so, any tips/how to? I don't have any diagnostic equipment to test for power getting to the motor, etc. No check engine light. |
with no way to test it then yeah get to throw parts at it until u get it fixed.
Best thing is to buy a service manual for your repairs |
You can buy a multimeter for a lot less than you'll spend on replacing good parts:
Search results for: 'multimeter' |
Found the solution.
It would appear the ground for the wipers was corroded and needed fixed. |
