2004 Sebring Convertible Water Leaking from rear of the Engine Block
I'm working on a 2004 Chrysler Sebring Convertible 2.7L DOHC 24 Valve. It was leaking water between the transmission and the bell housing meets the engine block. I was told that this was most definitely due to a bad freeze plug.
There is a hole in the engine block and it is not a freeze plug. This is where the water is pouring out. If you look at the picture you can see where I circled the hole. This is where the water is pouring out. Any suggestions would be greatly appreciated. Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting |
how do you know its not a freeze plug
The hole is not for a freeze plug.
