2005 Chrysler Sebring AC problems
I have a 2005 chrysler sedan, and when I turn the AC on, there is a leak in the back seat of the passengers side. Has anyone else had the same problem?
I have a 2005 Sebring sedan with the same problem. In summer when using the AC it gets wet under the passenger seat. Have yo been able to fix it?
Greetings from Spain :D |
Clear the condensate drain. Look for it as a tube coming out of the firewall behind the engine. Look for a rubber tube that comes out, turns down and just stops there. Try massaging it with your hand. You will probably see some debris fall out. Leaves and dead bugs that fall through the cowl vent wind up there.
