2006 Sebring Chirp when hitting small bumps/turning
whenever I hit a small bump or I make a turn there is a chirping noise coming from the general area of the front driver's side wheel. It is clearly heard in the cabin. anyone know what it is and how to fix it?
It's almost impossible to diagnose a sound unless you're there and can hear it yourself but a high pitched chirp like a bird makes is usually a sign of rubber rubbing against metal so you'd be looking for any rubber suspension parts that are worn or cracked such as your sway bar bushings for example...but like I stated, unless you're there to hear it it's almost impossible to say ...
Originally Posted by 05sebringconv
(Post 97073)
there are so many different parts it could be comming from that even with a video would be almost impossible to say for sure
I would buy a can of silicone based spray lubricant ( not oil based as it will destroy your rubber ) and spray one rubber part at a time until the noise goes away and then you've found the culprit...then change that part... since you get the noise when the car is moving or in a turn.... I'd go for the sway bar bushings and any links first...then look at such things as hood rubber, motormounts ect... you need to get under the car and examine any rubber component looking for a dry cracked one, then attempt to move it by hand to re create the noise, if you can't move it to recreate it, spray it with silicone really good and see if it goes away...if it does, change that part ....If you want to go the real cheap route you can try to spray it with a bottle of water, same effect it will lubricate for a little while and the chirp should disappear... |
