2006 sebring convertable
Old Nov 9, 2007 | 09:29 AM
newbe's Avatar
Default 2006 sebring convertable
heater controll only works on defrost . when i put the controll on floor i get nothing? any ideas?!
Old Nov 9, 2007 | 01:30 PM
moe's Avatar
moe
Default RE: 2006 sebring convertable
sounds likethe mode door actuator is inop.its a little motor that moves defrost or heat mode door when it is selected.moe
Old Nov 9, 2007 | 01:55 PM
newbe's Avatar
thanks moe
would this be a hard fix and or is ther a fuse i should check first?
Old Nov 9, 2007 | 02:00 PM
moe's Avatar
moe
its not that easy.back in the day there was a problem with a vac line that went thru the fire wall to your ac/heater box.not sure if your newer car still uses this method .wouldn't hurt to look under hood for broken vac line .pretty sure you don't have this set up.moe i'll look for picture of what your dealing with inder your dash. (mode door)
Old Nov 9, 2007 | 02:04 PM
moe's Avatar
moe
Old Nov 9, 2007 | 02:06 PM
moe's Avatar
moe
1 - BLEND DOOR ACTUATOR
2 - MODE DOOR ACTUATOR
3 - HVAC WIRE HARNESS
Old Nov 10, 2007 | 12:39 PM
Cordoba Man's Avatar
So they're motors now? Hmm! So that's why it doesn't change when going up a steep hill or stop the engine. My older ones always defaulted to defrost when loosing manifold vacuum.
Old Nov 11, 2007 | 03:22 PM
been motors for a long time now. Some systems have been vac plus motors but most everything now is motors.
Old Nov 11, 2007 | 08:14 PM
moe's Avatar
moe
this is one tuff job.and costly.moe
Old Nov 18, 2007 | 09:15 AM
newbe's Avatar
moe, thanks for your help. heater is now working.sorry it took so long to thank you but there was serious illness in family.
