2007 Sebring 2.7 Stalled and Now Won't start
Have a 07 Sebring, 2.7 v6 - Was accelerating to enter freeway and it just QUIT without ANY warning!!! Tried to restart and engine will turn over but starter will not disengage until you turn the key off. Engine will not even attempt to start either.
Battery is fine. No codes present Can somebody help me??? I looked for answers but didn't see anything just like this... Thanks in Advance! |
there will not be any clear answer to what U are looking for some one will need to look at the car put there hands on it and see whats going on.
I realize it is hard to trouble shoot a car over the internet. I just wondered if anyone else had something like that happen. Trying to gain a little insight from the experience of others. :)
u have not given any good data for which any one to go on
my car stopped wont run humm I would say 200 different things to start with could be wrong. |
07 Sebring stalling and won't start.
My daughters 2007 Sebring was stalling on her off and on. Check engine light was coming on and going off. Now today, when trying to start car it will just turn over and thats it. Odd thing is, when trying to start it, you can let go of the key and it stays cranking until you manually turn the key back off. Has anyone had this before???:mad:
Did you ever figure this out? I know its been a while but my daughters car is doing the exact same thing.
Could be the timing belt. Does it sound like it has any compression whatsoever? Does it make a consistent whining noise when it tries to start? If it had any compression, it would sound like it's trying to start, but can't. If the timing belt is broken (assuming of course the 2.7L uses a timing belt as opposed to a chain), the engine would have no compression because the valves are open on one side.
The 2.7 L engine has a timing chain, not a timing belt.
Ah. In which case nevermind :P
