2010 sebring blower only works on low settings
Old May 13, 2012 | 01:58 PM
esu's Avatar
esu
Default 2010 sebring blower only works on low settings
Hi, my daughter has a 2010 sebring, yesterday the blower started only working on the lower settings, it wont work on high. A google search led me to the blower resistor but that is for the lower settings, is there a seperate fuse/relay that covers the high setting?
Thx Cory
Old May 13, 2012 | 01:59 PM
esu's Avatar
esu
Should have added, 22k miles, 2.7 liter engine.
Old May 13, 2012 | 02:47 PM
take it to the dealer u are under warranty
Old May 13, 2012 | 04:23 PM
esu's Avatar
esu
I realize it's under warranty but she really cant afford to be without the car for a day or two not to mention that the Crhysler dealer nearest to me has idiots managing the service dept.
Old May 13, 2012 | 07:29 PM
gpatel's Avatar
Then change the blower motor resistor...lots of notes on this web site, same for other cars also.
$27 part at partsource and 15 minutes of work, usually located behind glove compartment.
Old May 13, 2012 | 09:05 PM
esu's Avatar
esu
Thx for your reply. Doesnt the resistor cover just the lower settings? My lower settings work fine its her hi that is out, or does the resistor cover both?
Thx
Old May 15, 2012 | 08:09 PM
esu's Avatar
esu
Anyone??
Old May 15, 2012 | 10:43 PM
Probably not the resistors, like you already figured out, the resistors are there to slow down the motor. Might be the switch. Might be the motor. I don't know about that year, but if somebody told me the body control module controlled the fan speeds, it wouldn't surprise me. You haven't specified whether it's ATC or not. If it's ATC, might be the blower control module.
If you don't want to have the dealer fix it for free under the warranty, then get a shop manual and study up on the problem.
Old May 16, 2012 | 07:32 AM
esu's Avatar
esu
dcotter, thx for the reply. I'm not sure what ATC but Im guessing some type of auto climate control>? If so she doesnt have it. I was just hoping the hi blower was protected on a different circuit by a different fuse/relay/fusible link etc like some other cars. Im guessing by responses or lack thereof that this is not the case. Looks like she's off to the dealer, Thx again to everyone that responded.
Cory
Old May 17, 2012 | 08:33 AM
teddysmith1952's Avatar
Cory[/QUOTE]
You are doing the right thing, particularly when it's under warranty. There are some cases where you just have to find the time to take it to the dealer. NO BRAINER!
