2012 Chrysler 200 trailer arm
I’m trying to replace the rear driver side trailing arm. I’ve got all the bolts off but do not know how to get the cable that runs through it off. I believe it’s the e-break. Any ideas. Thanks J |
Yes that is the E-brake cable. It has to be disconnected from the parking brake actuating arm and the cable sheath disconnected from its mounting point at the backing plate. Then you can bring the cable thru the hole in the trailing arm. YUP, there is some brake work involved in changing the trailing arm.
Originally Posted by REBEL59
(Post 107724)
Where is the parking brake actuating arm??🧐 |
Originally Posted by Jrberry13
(Post 107729)
Where is the parking brake actuating arm??🧐 depending on whether you have drum or disc rear brakes, the drum or rotor must be removed and the shoes probably have to be removed to have working room to unhook the cable eyelet end from the arm and work on releasing the clip that locks the cable to the backing plate. If you're in a high rust area region, have lots of penetrating oil handy :), good luck! |
(Post 107731)
Just woke up and NO MORNING COFFEE YET!!
You'll have to remove the rear caliper and take the rotor off, parking brake system is inside the "hat" of the rotor. It is set up much the same as a drum brake system..just no wheel cylinder.
YUP, a bit of work to do! |
Hi All,
Greetings! Hope you are doing well. please advice on how i can re-place on rear driver? if anyone have proper knowledge on that please suggest me. waiting for your kind co-operation. |
