2013 - 200 Reset Airbag Warning After Headrest Service
I removed the right front headrest to transport a ladder. I didn't realize that it has a sensor & I pulled the wires out of the connector.
When I put everything back together, I see the airbag warning light. I have 2 questions:
Since I pulled wires from the connector, I need to know if the wires are polarized; does it matter which one is attached on the right & left?
Also, how do I reset the Airbag warning once I have reconnected the sensor?
I found answers to the questions I posed on my own.
By looking at the wiring for the left front headrest, I was able to see the color of the wires that went from the headrest to the connector. Apparently I damaged the back of the right headrest connector that houses the female wire ends. So I inserted the female ends into the connector and used a glue gun to secure them from easily pulling out.
I then found that the Airbag warning went off on its own, so I did not need to reset anything.
SteveR
Aug 7, 2013 09:43 PM
Louie
Feb 13, 2008 06:34 PM
