2014 - 200S - Drvr Side Eng Oil Leak
Good Afternoon All,
I have a 2014, 200S w/55K miles on it. I discovered a pretty active leak yesterday. It seems to be on the drivers side of the engine block (perhaps the front main seal?). Has anyone experienced this premature failure? Any assistance with what it may be, or if it is covered under the drive train warrantee, would be helpful. Thank You in Advance, Cap |
Is the motor the pentastar 3.6 v6? if so the oil filter/ cooler assy is prone to leak..REPLACEMENT is the recommended fix. I t is located on top of the motor , under the dress up cover.
Front main seal would be on the passenger side, down low. Read through your warranty documents and if you think it should be covered, take it to the dealer and state your case.
