2015 chrysler 200
Could someone please tell me how to reset my tire pressure monitoring system? I have a 2015 Chrysler 200 limited.
Are you sure it's faulty? Maybe your tire pressure really is low. Check the pressure. Add air if low. For proper pressure, read the owners manual.
If you are sure there's a problem, take it to the dealer. It's probably still under warranty. |
(Post 95508)
Did you check the owners manual?
Who is "they"? I can't believe the dealership wouldn't take care of that under warranty. You may have a defective sending unit in that tire which ought to be covered. If, on the other hand "they" is some tire shop that worked on the tire, "they" may have damaged the sending unit, in which case "they" should fix it at their expense. |
Originally Posted by Joelb99
(Post 95509)
I've already checked my tire pressure and it's good but there is no reading at all for that tire on my dash. They told me that I would have to reset my tps but no one has told me how to do it
Hi Joelb99, A tire pressure monitoring malfunction can occur for a variety of reasons including the installation of replacement or alternate tires or wheels. Did you go to a dealer to have them check for you? Have you recently replaced tires? Either way, it is recommended that you take your vehicle to a dealer to have the sensor function checked. Let me know if there is anything I can do. Thanks, Kathleen Top Care Specialist FCA Canada |
