2016 Chrysler 200 rear defrost not working
Old Sep 18, 2019 | 10:21 AM
Jennifer Crandon's Avatar
Default 2016 Chrysler 200 rear defrost not working
My 2016 Chrysler 200 rear defrost not working even though when I push the button to turn it on the light does work, I have checked the fuse & it is fine. I checked the rear window for loose wires/connections but found no visible wires/connectors. What else can I check?
Old Sep 18, 2019 | 01:33 PM
You'll have to remove the trim around the window to reveal the connections. Check to see if there is voltage at the connections on the window when you press the button. If there is voltage there, but the grid doesn't work, then it's most likely that one of the connectors glued to the window has failed. There are repair kits you can buy with special conducting glue to repair the connection. Auto parts stores carry the kits.
yadog
Jan 3, 2014 08:34 PM
bgmoss
Mar 22, 2009 11:59 AM
abratt70
Jan 3, 2009 03:23 PM
ctribou
Nov 1, 2008 07:13 PM
courtneysebring
Oct 2, 2007 01:08 PM
