-   -   96 sebring 2.0 dohc timing belt replacement advice requested (https://www.chryslerforum.com/forum/chrysler-200-sebring-14/96-sebring-2-0-dohc-timing-belt-replacement-advice-requested-11000/)
septicman Mar 20, 2010 06:02 PM
I am replacing the timing belt, idler pulleys and water pump in my 96 Sebring coupe with the 2.0 DOHC engine. Has anyone had firsthand experience doing this job? There does not seem to be any way to remove the engine motor mount which attaches to the block with 3 bolts because there isn't enough room between the timing cover and and fenderwell. I got those 3 bolts completely loosened but can't get them out !
Is there a trick to doing this?
Any help would be appreciated.
Thanks in advance !
dcotter0579 Mar 21, 2010 12:47 PM
Have you removed the plastic inner fender (splash guard)?
septicman Mar 21, 2010 05:19 PM
Yes, I removed the plastic inner gaurd in order to get at the bolt closest to the firewall. All 3 bolts are loosened, but I still can't get them out.
Have you personally done this job on this engine on this car or a Dodge Avenger?
Thanks.
dcotter0579 Mar 21, 2010 07:52 PM
No. If you don't find anyone on this forum who has, you might try a Dodge forum or a Mitsubishi forum. The car was built by Mitsubishi, you know.
septicman Mar 21, 2010 08:25 PM
Thanks for that most excellent suggestion ! My authentic Chrysler manual is useless, but I have found Mitsubishi manuals (89 and 90 Monteros) useful.
