96 Sebring 2.4 Idle issue
Won't idle at all, 180 lbs compression on all cyl. Injectors and fuel pressure fine. Revs and sounds great. Used starting fluid everywhere, no vac leaks.
EGR moving. No codes. Put in new coil, wires and plugs just because. What next?????? |
better description to wont idle at all
Holding the accelerator pedal over 1000 rpm, let the pedal down slowly it dies before reaching 800 RPM. |
"What next??"
Dirty throttle body? Clean it. Idle air control motor. Check it. |
(Post 62454)
"What next??"
Dirty throttle body? Clean it. Idle air control motor. Check it. Rubber coupler, resonator to throttle body, ripped, dealer said good luck !!! |
oh that's your issue right there or part of it U must have a tight seal in that area for it to work
(Post 62456)
Part available anywhere you know? THANKS FOR THE HELP ! |
Also, why no codes ???
cant help with parts call around your area
Originally Posted by GaryRoe
(Post 62461)
