96 Sebring Convertible JXI Auto Shutdown Relay Fuse
Hello,
I have a 96 Sebring Convertible JXI 2.5L V6. Once my car has warmed up and I push down full throttle on the gas I blow my auto shutdown relay fuse (ASD). We have replaced the actual relay, the ignition coil inside the distributor, we have checked the computer for codes and nothing comes up, and we have checked the fuel injectors for open wires and we have not found anything. The car runs great. You can barely even tell its running. It starts up perfectly fine, and a complete tune up has been done(cap, rotor, wires, and spark plugs). Any suggestions as to what is wrong with my car? Thanks for any help you can give me. |
a wire that is powered by the asd relay is shorting out when u give it WOT get a wire diagram and start tracing all the items that the ASD provides power to or that fuse is on.
UPDATE: We have traced all of the wires and checked all of the ohs. Everything checked out perfectly fine. There are absolutely no problems with the wires.
UPDATE: We have unplugged the O2 sensor to make sure it wasn't that and it was still shutting down. We then replaced the fuel pump and the car is still shutting down. Taking it to the dealership today to see what they have to say.
UPDATE: We have also replaced the PCM. Nothing has changed.
Originally Posted by Ms.Scarlet
(Post 60033)
Hello,
Once my car has warmed up and I push down full throttle on the gas I blow my auto shutdown relay fuse |
This is while moving. Sometimes I can pop the fuse while in the bay without moving but its rare. It also happens at any temp.
Originally Posted by TNtech
(Post 60765)
Is this while moving or sitting still? ONLY warm engine or any temp? Alternator can also cause your problems.
(Post 60781)
UPDATE: Took the car to the dealership and they have no idea what is wrong. So much for them having all the right answers....
