96 sebring coupe shimmying
:confused: I was trying to get an idea and maybe somone else has had the same problem cause it can be a number of things
Under what conditions does the car shimmy? Braking, accelleration, turning, etc? Assuming you feel it through the steering wheel?
Yup, could be many things. Help us with a good description and we can help you diagnose it :) |
sorry to bump in but my car also gets very light shimmy at speeds around 100 km/h and over, it doesnt get too bad, it also shimmy's when i brake but its just the brake pedal mostly. my car was making loud grinding noises ( i thought it sounded like an old wooden boat creaking) it also feels a bit loose going over rough dirt roads
Originally Posted by 97 Sebring Lxi
(Post 36115)
The grinding noises and vibrations during braking are probably due to worn brake pads and warped rotors. A proper brake repair involves replacing these parts and should cure those problems.
"looseness" is a bit vague but could be worn ball joints or worn shocks/struts. Not surprising in a 13 year-old car. |
