98 JXi cooling fan relay location
I am unable to find the cooling fan relay on my 98 sebring convertible. I looked in the PDC and it is not there. If anyone knows they hid it I would greatly appreciate your sharing the knowledge.
Thanks for any help you can provide. |
RE: 98 JXi cooling fan relay location
RADIATOR FAN RELAYS - PCM OUTPUT
The PCM energizes the radiator fans through either the low or high speed radiator fan relay. The PCM controls the ground circuit for the coil side of the relay. Power for both relay coils is supplied through a 10 amp fuse in the PDC. Power for both relay contacts is supplied power through a 40 amp fuse in the PDC. Refer to Wiring Diagrams for circuit information. The PCM monitors the A/C compressor discharge (high side) pressure through the air conditioning pressure transducer. Depending on engine coolant temperature and A/C system high side pressure, both fans operate at either low or high speed. The radiator fan relays are located in the PDC. The inside top of the PDC cover has a label showing relay and fuse location. |
Thanks Moe. I didn't see the other part of the PDC underneath the hose from the air filter. Swapped the relay and it worked just fine.
| All times are GMT -5. The time now is 01:20 AM. |
