98 Sebring
Pardon my ignorance as I'm not familiar with these cars,though I recently did some work on a 99 300m 3.5. I found a 98 Sebring 2.5 that is in good shape but has an engine problem.From research I found the automatic came with a V6 2.5,is this a derivative of the 2.7?
No. Different engine.
Is it as problematic as the 2.7 seems to be?
I own two cars with the 2.7 and have had no serious engine problems with over 200,000 miles on the cars. The 2.7 has a timing chain rather than a timing belt. It also does not have a distributor, another source of trouble for the 2.5-3.0 engines.
If you are thinking of dropping a 2.7 into that car, forget it. The computer, wiring, plumbing, exhaust are all not going to match up. Not sure about the engine mounts. |
Thanks,I wasn't going to swap,just wondered if the 2.7 was a bored and stroked 2.5 engine.I do have a 99 Intrepid 2.7[my wife's niece's]sitting in the yard that has a "blown head gasket".Unfortunately a limb fell caving in the roof and busting the rear window.Why do you see so many 2.7's with problems,lack of proper maintenance? I have found a 99 Intrepid 2.7 for cheap and had thought of using the two to make one.I'm mechanically incline and have built half a dozen engines with good success.I was thinking of putting something together for my gran daughter.
