98 Sebring tachometer working backwards - circuit board / IC issue?
I have a 1998 Chrysler Sebring JXI . The tachometer started working Inversely. When you hit the gas, it comes down from 5000 RPM. The engine speed increases as normal. The car is mechanically OK. I dismantled the gauge cluster and found that putting a slight bend in the circuit board behind the gauges made the tachometer work correctly again. I took the gauge cluster out and re-soldered every single trace but the problem came back. I have checked everything with an ohmmeter On the component side and cannot find any bad traces. Has anyone encountered this, and what component did you focus on that has the problem? I just can’t find this electrical gremlin and it’s getting annoying. |
Originally Posted by fionamabe
(Post 116485)
The problem is more looking to be caused by the circuit board, you will have to work a little but it's not very hard to solve it, you can repair it by yourself or address to a company which will make and replace it. It won't cost you much because it's not a big problem, but even thus you will have to waste about 100 dollars. Knowing what are circuit boards made of then trust me that you aren't the first one with such a problem. I hope that it was useful for you.
Originally Posted by RoseParr
(Post 116486)
Thanks for the information.
