99 LXi Door speaker removal.
I finally blew the passenger door speaker from the infinity system last week. Problem is I can't tell if I need to pull the entire door apart to unhook the speaker until I can replace it, or if there is a much simplier way. If anyone has delt with this, I would greatly appreciate any and all help.
Thanks in Advance! Dustin |
RE: 99 LXi Door speaker removal.
hmmm..i have not removed mine, so im not sure...however, i used to work at a dodge dealership, and if you call a parts department, and tell them you work at a shop, and youre doing a window motor regulator, and you need to know how everything comes apart. OR go to a dealership and they will show you a schematic of the door assembly.
Well, finally figured it out. You have to take the entire door panel off to disconnect the speaker, ugh! :)
