99 Sebring Convertable directionals not working
Ok so heres the deal I just bought a 99 Sebring convertable for the summer and the directionals don't work.I checked the fuse and it is ok and all the lights work when turned but nothing from either directional.Any and all help will be greatly appreciated.
thanks Bob |
Check the bulbs again. The bulbs for the turn signals have two filaments. Just because the bulb lights when you turn on the running lights doesn't mean that the turn signal filament is working.
If it's not that, then the problem may be in the switch or the wiring or a ground. |
Besides bulbs, you may have a turn signal flasher out. Many people are also changing to LED bulbs also. LED bulbs are not compatible with the stock flasher because there is not enough current draw. If that is the case, change the flasher to an LED compatible one.
| All times are GMT -5. The time now is 06:27 AM. |
