99 sebring convertible jxi no power to #15 fuse
My turn signals and wipers are not working. I just replaced the turn signal switch with a brand new one. Changed the fuses and still not working. I pulled out the #15 fuse and checked for power and no power running thru it. All other fuses have power.
So where do I go from here? I'm not a mechanic, fairly newbish. But i get my hands dirty, and just need to get this car working. Appreciate the help. |
Fuse 15 gets its power through the ignition switch. Is the switch on when you are checking for power? If so, you might have a problem at the switch or in the wiring between the switch and the fuse.
