99 Sebring exhaust manifold very hot
Old Aug 31, 2013 | 08:30 PM
OldGunz's Avatar
Default 99 Sebring exhaust manifold very hot
I have a 1999 Chrysler Sebring with a 2.5 liter V-6 and it sat for several months. I just changed the plugs, wires, cap and rotor and started it up and it idles rough. I test drove it a few miles and it just got worse and cel came on, and the rear exhaust bank pipe got red hot. I am wondering if my map sensor is out or the O2 sensor is bad? Does this sound right? I don't have a code reader, but I am thinking since one side got hot and the other didn't it almost has to be a sensor. When i take the little hose off the top of the intake plenum it changes the idle considerably, it actually sounds better. Any thoughts?
Old Sep 1, 2013 | 07:46 AM
"I just changed the plugs, wires, cap and rotor "
Id say i mixed a wire up on the plugs
Old Sep 2, 2013 | 10:16 AM
OldGunz's Avatar
It was getting really hot on just the one side of the exhaust. It was red hot on the exhaust bank next to the firewall. I am sure the front bank was hot, but it clearly was not as hot as the back. Would that still be something like a mixed up plug wire? I was pretty sure I got them back in order, but it is possible they are off by one. I was thinking that since the idle changed when I removed the little vacumn line on the top of the intake plenum that might point to the O2 sensor or the map sensor. Am I a bit off on this? I am sure they need replaced anyway since they look original.
thanks for the help.
Old Sep 2, 2013 | 11:54 AM
was this an issue b4 u replaced the plugs and wires? if not then more then likely u caused it
rhino
Jul 23, 2015 08:29 PM
G Bender
Oct 8, 2013 01:20 PM
Cliff250
Feb 11, 2012 01:58 AM
onecheck
Mar 4, 2011 08:40 PM
simonda
Jan 3, 2010 02:44 PM
