ABS codes for 01 Sebring
How to retrieve ABS codes? My OBD scanner (80 doll) doesn't show ABS codes. I couldn't find anything on internet except 98 Sebring (ground terminal, see flashing). Doesn't work for 01 Sebring.
My ABS and break lightsare on. I will check wheel sensors. Let me know about some website, please. Kia has all tech info on their website, why Chrysler doesn't? Or I missed it? Thanks. |
RE: ABS codes for 01 Sebring
hehe the OBD2 scanner is just for what its is called ODB all check engine lights.Airbag Abs and nething else does not have a thing to do with ODB or federal emissions. U will need a more advanded computer or a dealer computer in order to get the codes for the light. All the TBS infor is posted but it may or may not even be for what the code is I doubt it though. I would say sensor or something but have it checked out and go from there.
Thanks. Light disappeared itself. It was from discharged battery probably.
was the other lights flickering like the milage?? if so then yes low batt if not have an issue and it will come back.
ORIGINAL: CHRYSLER TECH was the other lights flickering like the milage?? if so then yes low batt if not have an issue and it will come back. |
