Adding automatic headlights 2004 Sebring Limited
Hello, I have a 2004 Sebring convertible Limited automatic with the 2.7L engine and I would add automatic headlights on my car.
I own the multi-function switch with fog lights and automatic headlights and also a light/sun sensor that is positioned in the dashboard under the windshield. It missing the wiring diagram to connect the light sensor at the BCM. The Turn Signal switch with auto headlights 4608808AF https://www.rockauto.com/info/903/1S7768.jpg The sun sensor 04698662J http://i.ebayimg.com/00/s/NDgwWDY0MA...RUlJEh/$_1.JPG Pinouts http://ww2.justanswer.com/uploads/VL...33119_conn.jpg Thanks. |
Wiring diagrams are found in the factory shop manual. They occupy over a hundred pages. They do not go into the internal programming and connections of the BCM, however, and it will be the BCM that actually controls the operation of the lights. Your BCM may need to be either replaced or re-programmed to incorporate this function.
Normally the BCM is able to handle this function.
I have the 04602369AC modele (the high-end BCM management with automatic climate control, radio control at the wheel) |
