dcotter0579 |
05-19-2014 04:14 PM |
Probably a plugged drain. It happens when small leaves and such crud from trees fall into the cowl openings in front of the windshield. Look at the steel firewall behind the engine, and look for a rubber tube that comes out, turns down and connects to nothing. That's the drain. Try massaging it to crush the crud in there and with any luck, the stuff should fall out the end. The end is usually flattened but if you squeeze it, it will open and the stuff will fall out.
