Anyone use this Intake for the 2.7L
I was just wondering if anyone has used this Intake on there 2.7L sebring, http://weapon-r.com/english/index.ph...oducts_id=5415
RE: Anyone use this Intake for the 2.7L
Not me. I think the stock box is pretty big. I don't remember where I saw it, but there was a study on cold air intakes on a charger Hemi, and none of them produced more horsepower then the stock box with a clean paper filter. Some were even worse than stock. Unlike Ford, Chrysler has done a pretty good job of producing silenced air intakes that actually flow.
I see u have been misinformed … big time..
Big box does not mean good flow because your stock filter is very restrictive, you have very restrictive silencer (it you took it of you still have small hole to the box), intake rubber tube often has groves – does not allow smooth flow. All cars gain hp from performance intake (but not equal)…..boosted cars (turbo or SC) gain much less (some times 2hp … because they are F/I). Intake from eBay will give you same gains (if there is one) but the filter quality will be low (you can always buy dif. Filter). http://www.hemitruckclub.com/afemark.htmthe only way performance intake will not add hp to hemi is if they use a tiny filter meant for a small 4 cylinder |
If you realy want to go with wepon R then try this website:
http://www.racinglab.com/wr-secret-307-150-1.html Cheaper way to go about it is to buy weponR filterfrom that website and buy Intake pipe from ebay for $30 you can buy this one: http://cgi.ebay.com/ebaymotors/01-04-Dodge-Stratus-Chrysler-Sebring-2-7-V6-Air-Intake_W0QQcmdZViewItemQQcategoryZ38634QQihZ008QQi temZ180173186219QQrdZ1QQsspagenameZWDVW or you can buy one for different car that has angles that you need and cut pipe to the length you need (CAI will have few turns in it and longer pipes- so you can cut it and customize it the way you want it to go...away from engine. |
So you dont think getting the whole short ram would be better from Wepon R, or would it be best to just go with the ebay one and put a k&n on it? Also since it is open to the engine would a heat shield be best to add since the fans do blow heat into the engine bay?
