Broken Valve TPMS
So I was reading up on a thread posted by another member on here.
That his valve stem broke on him, Same thing happened to me today. I've currently by passed the problem by taking that pointless sensor off and putting a rubber valve back In. The new problem I have now Is that damn tire sensor light won't go out on the dash. :mad: Other then ripping the dash apart and taking the bulb out or putting a piece of tape over the Icon, Is there anything else I can do to make It go away? Any suggestions would be much appreciated. |
I've currently by passed the problem by taking that pointless sensor off and putting a rubber valve back In. The new problem I have now Is that damn tire sensor light won't go out on the dash. You will be doing one of two things....replacing the sensor, or enjoying the newfound "DASH ILLUMINATION".... Just think for a moment, ....If the sensor measures air pressure and reports back to the controller, when a tire is low on pressure.....why would you NOT expect to see the light on if you removed one of the sensors.???? |
