A/C compressor
Is there any way you can take the bearings off the compressor on Sebring '02 2.7 without taking the lines off. I took the belt off and when you move the A/C compressor pulley by hand it makes noise.Also about the idler pulley. When are you suppose to replace it? The belt looks kind of cracked So I'll probably replace it. I guess the main thing is the A/C compressor. Car has about 98000 miles.
Аny suggestions? |
going to be tight in the car ,but i beleive you can remove the clutch housing.might need snap ring plyers
I just changed out the compressor in mine last summer and I would not want to try to work a clutch puller in there, but perhaps it can be done. The more relevant thing though is that a clutch pulley will cost close to $200-- that might be better spent toward a complete compressor since yours is probably old.
