dcotter0579 |
05-19-2019 04:13 PM |
Bolt torque specs are a function of the size of the bolt. There are charts on line you can find easily. Those bolts holding the caliper are pretty good sized. They will take a pretty good torque. For most purposes, the torque for a big bolt like that is "all you can put on it with a normal ½ inch ratchet." (Unless you're an Olympic weightlifter. Then put on a little less force than that.) The point is, that an exact torque is not critical. You want it good and tight.
