Car alarm with remote start and central lock wiring. (Pics inside)
6 Attachment(s)
Hello everyone,
Since my car doesn’t have any alarm installed and the remotes for central locking are not long range even with new batteries, I decided to get a new alarm system with remote start and two way remotes. My car is a Sebring LX 2.7 out 2002 I did install car alarms before and I am electronics engineer ( not for cars) so I understand the inner workings. But I still got two questions about the central locking and the remote start by-pass. Before I ask the questions, here is the wiring diagram for the alarm: Attachment 1816 And here the wires in the car: Attachment 1817 My first question is about the remote start by-pass, I never installed a by-pass kit before and the one I got is from BYPASSKIT type PKUCH, this should work on my car. In the manual it says I shouldn’t wire the module while programming and at step 4 it tells me to hot-wire the car for ignition, can I use a regular key without a transponder to power up my car ignition? If so I can go to a key maker and copy one of my originals with a simple key. By-Pass kit manual: Attachment 1818 My second question is about the central locking, as you see on the second picture above our cars have a single wire LOCK/UNLOCK (white/green) and the alarm module I have has 6 wires for central locking. There are some wiring suggestions in the alarm manual about the central locking systems but none of them is for single wire. And I read about Chrysler single wire system needs resistors to work, for locking 1800ohm resistor positive signal and unlocking 750 ohm resistor positive signal, is this true? If so I can work out those 6 wires to see which one gives positive pulse when locking and unlocking (it should be the 4th diagram in the image below) Suggestion diagrams from the alarm manual: Attachment 1819 Any suggestion from someone who installed similar alarm and by-pass module is greatly appreciated :) PS: If something doesn’t make sense, don’t hesitate to ask me please, my English is not that good but I will try to clear things up. This is the alarm I got: Attachment 1820 And this is my car: Attachment 1821 |
