Change Oil Light - wont go away
After leaving Jiffy Lube, I noticed the 'Change Oil Light' was still there. So I called the Chrysler dealer and they had me do these steps, but it still is there.
Turn the key to the on spot. Press the break pedal three times. Turn key to Off. I tried the above several times. Tried it with the door open, with the door closed. Turned on the car afterwards. But it will not go away. Any tricks?:mad: |
Press the accelerator 3 times all the way to the floor, not the brake pedal
Originally Posted by ruttrow
(Post 36817)
When all else fails, try reading the owners manual.
