Convertable top Replacement
2006 Sebring, rear window is cracked, thinking about getting a complete top for a salvage yard and swapping. What year span fits the 2006? Is the replacement bad to do
A top from 2001 through 2006 should fit fine. Removal and proper installation will not be easy. Installing the top is not all that difficult, but installing it well so it fits tight and without wrinkles is the challenge. Your best bet is to explore all possible options, including buying the replacement top and having it professionally installed. There are people who specialize in that kind of work, do it all day every day and do it very well and efficiently as a result. There are sites on the internet that sell tops and also provide installation instructions. You should look for those sites, study the instructions and decide if you and your toolbox are up to the task and go from there. You should visit a shop that installs tops and talk to them about whether they will install a top purchased elsewhere. Watch their work and see if you can pick up some pointers. Replacement windows can be purchased separately if you just want to fix that problem. Come back and tell us how it went and what recommendations you can give to others.
Originally Posted by illenema
(Post 111518)
I did not get to finish my swap due to an illness and the donor car being salvaged!! |
Thanks for reply, Got a donor 2004 Cloth top complete with frame ect going in the 2006
Take pictures and come back and tell it how it went. It's okay to brag a little.
Take pictures!!! Nuttin wrong with showing off!
Okay, There is a great salvage yard Taking a complete cloth top which will be an upgrade from the vinyl one.
We had a plastic window looks like a replacement, wife rolled down the top in the cold and cracked it out. Ha |
| All times are GMT -5. The time now is 01:12 AM. |
